Old 04-05-2006, 01:15 AM
Brent Mills's Avatar
Brent Mills Brent Mills is offline
Administrator
Default TWM Induction systems for your Cobra from Thor Motorsports.
From member thorconstr,
Thor Motorsports
Competition Fuel Injection
Systems and Accessories
2609 North Forgeus Avenue
Tucson, AZ 85716
520-401-9142
Al Wohlstrom
thorconstr@msn
Pricing for TWM 427 Ford Injection
TWM 427 58mm kit, includes manifold for distributor, 4 two barrel 58mm throttle bodies, fuel rails, manifold mounted linkage, vacuum lines with plenum and air horns.
Bosch 42# or 65# injectors.
Aeromotive A1000 fuel pump, regulator, and filter.
F.A.S.T. XFI ECU, harness and O2 sensor.
MAP, water, and air sensors.
Crank trigger.
Polishing for manifold, throttle bodies, fuel rails, and air horns.
Shipping for the above.
