The new body doesn't have the flange under the rocker, the front flares are
slightly different, and some of the assymetry has been removed. We left a little for originality.
If you look inside the nose, there's lots of new original-looking tubes that integrate with the new body, bumper and radiator mounting systems, and a different mount for the optional front fans.
The front and rear wheel housings and trunk inner panels are now aluminum.
More stuff that I almost forgot... We've eliminated the step under the door sills and the tunnel is now aluminum and a bit higher to clear the Tremec shifter without a spacer.
