  #24 (permalink)
Old 04-07-2006, 10:28 AM
Tony Ripepi's Avatar
Tony Ripepi Tony Ripepi is offline
Cobra Make, Engine: TBD
Hello Rick,
I have CSX4264 in my garage and really love the car, mine has a 427SO from Southern Automotive and 4-speed top loader. The car you are looking at looks great and it has an Aluminum 427 with a 5-speed. The 4-speed is traditional, the 5-speed is easier to live with. I think the $92,500 number is a fair price for this car IMHO
You need to drive it, get it on a rack and inspect it end to end for oil leaks, bottom damage, scrapping under the oil cooler, look inside the Wheel wells, look at the fit of the Aluminum kit etc. etc. You may even try to hook up with a mechanic you trust to check the compression ratio across the cylinders , drive shaft run out and general condition of the installation. If something is wrong inside that motor you could get it home drive a few thousand miles and then the issues that 427's are famous for could present themselves as an expensive thrill.
Here is another Aluminum Continuation Cobra at Fantasy Junction:
http://www.fantasyjunction.com/used-...e06e2e3758e205
BTW they also have a new Ford GT there for $179,500.
Tony R.
