Thread: setting up PCV
Old 04-09-2006, 01:54 AM
Jeff Frigo's Avatar
Jeff Frigo Jeff Frigo is offline
Cobra Make, Engine: ERA 454 S.O.
Originally Posted by Buzzmobile
I bought my car 2 years ago and it did not have any PCV set up so, I am researching what I need. my plan, put a breather in one valve cover (does it matter which one?), and then I need a breather/PCV combo on the other side to be attached to one of my carb inlets/vac (any suggestions?). I have 2 carbs...either one? any advice on which PVC valve, I understand that they need to be "matched" to your engine. I have a 427 SO by Keith Craft, just under 600HP. Any and all help appreciated as usual
thanks
Buzz
Why do you want to run one?
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
