Originally Posted by Rick Parker
Excess oil collecting in valve covers and being sucked past valve seals.
That's a lot better than Blowing Chunks!
I second this diagnosis.
Do you have the
oil feeds restricted to the rocker arms?
Old FE trick to put holley carb jets(90) in the
oil port under the rocker stand to restrict oil flow.
You also should check the valve stem seals.
