Old 04-10-2006, 10:37 AM
STEVE POTTS's Avatar
STEVE POTTS STEVE POTTS is offline
Cobra Make, Engine: Midstates, 427FE stroked to 482CI
Blykins,
The Mcleod parts I ordered are as follows:
28 pound Steel Flywheel #463215
Pressure plate #360821
Disc 260873R
Mcleod tells me that the bolt pattern on the flywheel/pressure plate is the 11.5" pattern but the 12" clutch disc fits within the bolt pattern.
Also, the R after the disc # means "reverse hub". I am running a TKO 600 which has the 1 1/8 x 26 spline input shaft...apparently this is a standard chevy spline pattern and diameter. But the hub needs to be reverse oriented for some reason.
I ordered the parts through summit
Steve
