Old 04-11-2006, 01:23 AM
Jeff Frigo's Avatar
Jeff Frigo Jeff Frigo is offline
Cobra Make, Engine: ERA 454 S.O.
Originally Posted by ted
A competent balance shop can match balance the replacement flywheel to match your old flywheel. The only nuance is if the flange on the back of the crankshaft is not exactly true with the mains, then a given amount of unbalance will occur as a result of the runout at that point.
Ted Eaton .
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
