The only coolant that will remain in the block will be from the bottom of the water pump to the bottom of the block within the block. Everything above, including block, heads and manifold will drain out through the lower hose into in the radiator and out the petcock. Very little coolant will remain. You may also fill it with water and drain it a 2nd time, diluting the remaining coolant before adding distilled water and water wetter during the final fill.
Rick
