Old 04-12-2006, 01:44 AM
kmarccoco kmarccoco is offline
Cobra Make, Engine: ERA
doug, i had a similar problem. does the front of those toggle switches heat up at all? where the metal washer screw is on the front. i found out that the rear of the switch had the bottom wire connector touching the metal lip on the inside of the dash.. i just bent them up a bit...
