Old 04-12-2006, 08:34 AM
REDSC400's Avatar
REDSC400 REDSC400 is offline
Cobra Make, Engine: ERA #375 427 S/C - 428FE - Toploader - 1968 AMX 390 Go Pack 4 Speed - My Daily Driver is a 2004 Crossfire
Send a message via AIM to REDSC400
You may want to check your ground. On the ERA the ground for the headlight and parking lights and fans is up front on the "X" member. I had an intermittent grounding problem in the past. With Bob's guidance, I narrowed it down to the ground at the X member. My frame was powder coated. The Ground point at the front X member needed to have some of the powder coat chipped away with an Xacto blade and then I cleaned the ground point where the screw applied pressure to the wire bundle connection. I also applied some dielectric grease to the hole as well as the wire connection. Since then all is well. My headlights are now very bright as a result.
So check your ground point would be my advice.
Art in CT
See My Website at http://www.lithicsnet.com
A car can massage organs which no masseur can reach. It is the one remedy for the disorders of the great sympathetic nervous system. Jean Cocteau 1889-1963, French Author, Filmmaker
