Mike, " if " the side pipes are questioned, would you let us know whether the Inspectors use a dB meter or their judgement/discretion in determining what level of sound is too loud.
Somewhere ( ? ) , I had seen the term reasonable w/o a technical spec. Also, if the dB is measured, the distance from the side pipes and whether at idle or a requested RPM. Due to the judgement factor, I would like to think there has to be a published standard. If the test arrangement is still the same as in 2000, the exhaust sound will be louder within the enclosed inpection lane.
Guess on my part, the open pipe or unrestricted muffler on Harley's would also be considered loud but have never heard of a Harley failing inspection for the exhaust dB
