Old 04-17-2006, 03:25 AM
Stuart Stuart is offline
Cobra Make, Engine: G-Force 5.0lt HO EFI T5 Jag SeriesIII Suspension
Hi Stphen
When I purchased my engine it came without any pulleys and I found the standard pulley setup as you have, did not fit. I chose to go with a pulley setup from March Performance (photos in my gallery, purchased from Summit Racing), this gave it more of a cleaner look and everything fitted pefectly.
Your gear box does appear to be set further back than my own, I do remember having to modify the rear gearbox mount further back, but luck was on my side as the gear shift alligned perfectly with existing hole cut in the tunnel.
But I did not have to change the postion of the front engine mounts.
I apologize I cannot give you any measurements as my car is at a workshop getting ready for rego.
Thanks
Stuart
