Thread: Rear End Whine
Old 04-17-2006, 11:46 AM
zipzip's Avatar
zipzip zipzip is offline
Cobra Make, Engine: Midstates work in progress, personally built 302
Whine in a spiral bevel set is almost always from contact pattern. A bad contact pattern may come from too much backlash, but the pattern is the key.
see pg 18 of http://www.arrowgear.com/pdf_files/catalog.pdf
Take the suggestions and double check yourself, or bring it to a reputable shop. I've found that a lot of times a local drag racer will be better than a "mechanic" shop.
You might be a redneck if you think the National Anthem ends with "...Gentlemen, start your engines."
