  #32 (permalink)
Old 04-17-2006, 06:11 PM
RedSnake351's Avatar
RedSnake351 RedSnake351 is offline
Cobra Make, Engine: ACE, 351W, 3550 Tremec, Raging(?) Red W/ White Stripe.
Originally Posted by OhBuoy
Gentlemen, if my car does not stop puking coolant, I may be driving the Grand Prix!!!. I am starting to get worried that it is a head gasket, and plan on doing a compression test tonight or Wednesday. Also plan on getting a cooling system pressure testor.
Tom, how much is it puking and does it go into a puke tank? You know that the coolant will not be (and should not be) right at the top of the highest point of your coolant system. As a comparison, a car with a standard radiator, the fluid will be several inches below the filler neck because when the engine is hot it will puke out about a quart or so (depending on the capacity of the coolant system).
Need more info if you are familiar with the above and there are other issues.
Ralph
SPEED WAS HIGH - WEATHER WAS NOT - TIRES WERE WET - X MARKS THE SPOT
Burma Shave
