Old 04-18-2006, 12:47 PM
jarendall jarendall is offline
Cobra Make, Engine: StreetBeast 66 replica 302 350HP
I put a loop in my vent line at the top, I used 3/8 aluminum line which is easy to bend, I ran the vent up next to the filler cap, looped it and back down below the fuel tank, so any overflow will not touch any part of my car, without the vent your gas tank could collapse from the suction of the fuel pump, if your filler cap is not sealed then you can simply insert the vent back into the fuel tank fill line, check to see if your filler cap has a gasket in it.
PapaJohn
