Old 04-19-2006, 05:50 AM
Woodz428's Avatar
Woodz428 Woodz428 is offline
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
There's really only 2 possibilities, one, a hole has eroded through the timing cover( the pump uses the cover as it's backing) or the 2 big passages have a bad gasket. If it is a pretty good leak, I'd pull it off and inspect. If it is a minor bit, tightening may seal it. If it does, I'd still pull it at the earliest convenient time, it probably won't stay sealed permanently.
WDZ
