Old 04-19-2006, 11:20 AM
d_ford's Avatar
d_ford d_ford is offline
Cobra Make, Engine: CSX4000, Shelby aluminum 496 ci FE
Default ERA turn signal and tail light help
I don't have either rear turn signal and only one tail light. I don't know for sure if this just happened or if I bought the car this way, I know I've checked front turns before (they still work) but I can't remember if I've ever checked the rears. I had the tail lamp socket out today to replace the gasket and after I re-installed it the tail light didn't work either. I've got power on the wire, using a test light, but the bulb won't illuminate. this car has the loop type connectors on the socket that a male bullet connector slips into. The connectors seem loose on the socket and can be wiggled back and forth. Are they prone to lose connection and are they still available or is there an updated version? I'm going to investigate this further when I get home tonight but was wondering if I could get any ideas before I start on it.
Thanks.
Doug
CSX4761
ERA #115 - sold
ERA #002 - sold
07 GT500
66 GT350 tribute
70 Mach 1
65 Comet gasser
