Old 04-19-2006, 08:39 PM
Iceberg's Avatar
Iceberg Iceberg is offline
Cobra Make, Engine: SPF 2369; Keith Craft 427FE Alum w/614hp. & 1999 Lotus Esprit V8, 375hp
It does not click into the other gears at all and can not be forced down into the positions. In neutral it will swing back in forth as though it were in neutrual but is not. I learned this when let off the clutch. It is clearly stuck in third.
As for thr third forth postion, you are correct. It is straight down from third.
No problem on the questions, I appreciate the any help.
