Old 04-22-2006, 08:17 AM
FFR428's Avatar
FFR428 FFR428 is offline
Cobra Make, Engine: HM-2027 / 427 SO
The aluminum BT cover I mentioned come in closed, open (for baffles) and a comp version. They run around $200 a set. The comp filter set is another $40-60 depending on the set. You can have them polished and the fit is very good on the set I have. If your running rocker end stands the stands might need to be clearanced tho... they covers are pretty thick. I remermber someone here having that problem not that long ago.
G.
