Old 04-22-2006, 04:24 PM
Sledge's Avatar
Sledge Sledge is offline
Cobra Make, Engine: BDR #168 427W 66+K miles and counting
Default Mechanical Brake Light Switch
Not pretty, but if you are thinking about replacing your hydraulic pressure brake light switch with a mechanical switch, here's one way to do it. Total cost less than $30. Peace of mind: priceless. Uses Brake Switch Plus #L08 from Watson's Streetworks. I am not an employee of Watson's, just a customer. I'm also not a pro photographer (as you will see).
Respond to this thread with your e-mail address and I'll send you some .jpg files and a two-slide Powerpoint file with directions. Let me know if you can't use Powerpoint files, I'll send the slides as jpg's instead.
