Be careful with this conversion. Many times with the serpentine belts, the waterpump is a reverse direction rotation, they are driven by the "BACK" (smooth side) of the sepentine belt. Be sure the direction of rotation is correct when the "V" belts are installed. You may need to install an earlier year model pump. Verify the direction the pump spins now. Good luck
Rick
