Old 04-24-2006, 06:46 PM
mts mts is offline
Default Factory Five MK II #5015 for sale
FFR 5015 is recently completed and road tested and now is up for sale to move on to another project. She was built as a street car that could shine at the occassional lapping day.
She has about 500 miles on her including a test and tune lapping day where she did very well. There is over $45k invested in the car, asking $31,900.
The car is registered, plated and titled as a 1965 certified historic vehicle.
PM me with questions, or email to mshepherd@ddfky.com, or phone is 859-425-7637.
Parts list is below.
Engine & Exhaust
-1995 Ford 351 professionally dyno tuned by SR Racing
-rebuilt .030 over
-Eagle rods
-SRP Forged pistons, 10.5:1 compression
-Stock crank, never turned
-Comp Cams Hydraulic roller camshaft .565 intake lift/ .574 exhaust lift, 282* intake/290* exhaust, 112* lobe seperation, RPM range-2500-6500
-Edelbrock Victor Jr. Heads (unported)
-# High-flowing 210cc intake ports and .130" raised 75cc exhaust ports
-2.05"/1.60" valve size
-Edelbrock Victor Jr. Intake
-ARP bolts
-Replica parts waterpump kit
-Mr. Altenator 95 amp alernator w/ regulator wiring kit.
-Holley 670 Street Avenger with electric choke
-MAC shorty headers coated w/black Jet-Hot 2000
-FFR catalytic converters coated w/black Jet-Hot 2000 (extra set of J-pipes too)
-FFR 4x4 side pipes coated w/black Jet-Hot 1300
-Mike Francuck side pipe heat shields coated w/black Jet Hot 1300
-Crane 1.6 roller rockers
-Mallory 4309 return style fuel pressure reulator
-Aeroquip –8AN braided stainless steel hose in engine compartment
-Ron Morris Performance 3/8 inch Nylon fuel line/ fittings from tank to motor.
-New stock 1991 Mustang fuel pump/screen
-1991 Mustang fuel tank
-Black “Cobra” valve covers from Ford Racing
-Cobra 18” black air cleaner from Ford Racing
-Tristate Motorsports aluminum radiator.
-Billet aluminum “T” filler with new radiator cap
-9mm Ford Racing spark Plug wires
-Braided custom Lokar stainless steel dipstick
-New upper and lower radiator hoses.
-Chrome fuel filter.
-Lokar throttle cable
-MSD 6-AL Ignition w/ hidden kill switch and multiple Rev limiter chips
-MSD Billet distributor
-MSD Steel distributor gear for roller cam
-MSD ignition advance kit
-MSD Blaster coil
-Energy suspension poly. Engine and Trans. Mounts
-Extra set of solid engine mounts as well
-Mr. Altenator New Ford Mini-starter
-Dyno’d at 320 rwhp WITH cats
Transmission/Rear-end
-Tremec 3550 5-speed. Proper tremec fluid. 3.27, 1.98, 1.34, 1.00, .68(OD)
-Tristate Motorsports new shortened driveshaft.
-Aluminum clutch quadrant and adjuster
-Steeda adjustable clutch cable
-Steeda Tri-Ax Billet aluminum shifter for Tremec 3550
-SPEC Stage II Clutch (SPEC PN SF482) rated 520 ft/lbs
-Ford MotorSport Aluminum Bellhousing
-Ford MotorSport Billet flywheel
-8.8 ford live axle from 1991 Mustang. All new seals, bearings, brakes, axles, etc
-Ford Motorsport 3.55 gears (new)
-Trick-Flow aluminum diff cover with heat sinks
Wheels/Tires
-Wheel Replicas Mustang Bullet, Black center section. 17 x 9 front, 17x 10.5 rear
-Nitto NT 555R 315/35 drag radials, rear.
-Exclaim UHP 245/45 Z rated, front.
-Track Wheels & tires available but not included in price
Brakes/Steering/Suspension
-Front Brakes – Levy Racing Wilwood 13” vented rotors w/6-piston calipers and speedbleeders(5 lug).
-Rear Brakes – Levy Racing Wilwood 12” rotors w/4-piston calipers, Levy parking brake and speedbleeders (5 lug).
-Wilwood Q compound pads
-Wilwood brake proportioning valve in cockpit
-Lokar parking brake handle and brake lines
-Tristate Motorsports Pre-Bent brake line kit
-Tristate Motorasports Pre-bent Rear brake line kit
-Front Stainless Steel braided brake lines
-8.8 axle rear braided brake lines
-1984 Jeep cherokee Brake Master Cylinder
-New front wheel bearings/seals
-Tubular upper and lower front and rear control arms
-Fortes 18:1 manual rack
-Levy Racing Street bump steer kit
-Breeze lower steering shaft
-Tristates upper steering shaft
-Pro Shock shocks and adjustable height coilovers
-Front/Rear spring rates 450/250
-3-link bundle. Includes 3-link setup, coilovers, tubular rear control arms
-Vintage Performance adjustable front & rear anti-swaybars
Body & Cockpit
-Breeze Street Performer seat mounts
-Street Performer seats with professionally installed seat heaters (driver and passenger)
-Compact Heater from Campbell Cobra products
-It’s a Snap wiring harness
-(2) 12v accessory outlets under dash
-Aluminum gas pedal
-Roush Racing aluminum brake and clutch pedals
-Replicaparts reconditioned pedal box with brake pedal mod for manual brakes
-Replica Parts under dash filler panel
-Optima Red Top battery ULT-9004-003
-Battery cut-off switch in cockpit
-Billet aluminum battery hold down
-Insulation/sound deadner in cockpit and trunk
-Rubber undercoating under fiberglass body and on exposed aluminum
-Thermo-Tec 2000 degree reflective panels in engine bay and footboxes
-Black carpet in trunk
-Autometer 427 Replica guages w/ reverse speedo & oil temp gauge
-Braided oil pressure gauge line Reverse speedo adaptor
-New 60” speedo cable
-APE hardtop with window kit
-14” Leather steering wheel
-(2) Raydot spun aluminum racing mirrors
-dual roll bars professionally powdercoated black
-Russ Thompson rollbar bezels
-hood hinge kit
-Bethania Garage stainless front and rear bumpers w/Finish Line front and rear rubber body gromets
-Breeze radiator cover
-Levy leather door panels
-3M clear bra coating kit
Accessories
-Powered by Ford side emblems
-Cobra Nose and Deck emblems
-Vinyl static cling fender stipe, Red.
-Shelby VIN Plate w/ “FFR5015R” engraved
-Finish Line starter button
