Old 04-24-2006, 07:04 PM
Rick Parker's Avatar
Which springs do you have on the advance weights? If they are the very light silver ones (weakest, that allow the quickest advance rate) and if the nylon pads under the advance weights are worn there may be some resistance or drag preventing them from returning to baseline. You may also need a small amount of lube in and around the advance weights.
Rick
