Old 04-25-2006, 12:20 PM
Rick Parker's Avatar
An Afterthought: Some of the HD aftemarket drive shafts have different length hex reliefs machined on either end, the broached recepticals on the oil pump and the distributor shaft are different depths and if the drive shaft is installed upside down it will jamb the distributor shaft upwards causing it to bind as it is tightened down.
Rick
