Great news, Ray
You should remove the visors (sorry, forgot about that - I did too), as NYS requires the visors to be padded if they are on the vehicle.
I was told I had to change to amber lenses (I originally had amber bulbs under clear lenses). I got my amber lenses from Finish Line.
I mounted my reverse light to a bracket/tab underneath that looks like it might be for mounting the undercar exhaust on the roadsters. If I remember right, I think the switch on the trans completes the ground for the circuit - there should be a power wire hidden in the harness in the trunk. If you are not sure, give your dealer a call, ot let me know and I will check it out.
From my experience, if there IS a concern with your car during the actual inspection, they will tell you exactly what you need to do to comply with the regulations. All the DMV people I dealt with during the process with my car, and another SPF, were very helpful.
May 5 - that's also the day we should be closing on the new house! Be sure to let us know how it goes!!!
Jim Kellogg 887
Elmira, NY
