Old 04-28-2006, 06:27 AM
Cracker Cracker is offline
Default 427 s.o. for sale - Atlanta
SOLD
Price? Willing to look at reasonable offers.
Why? Business/Invention is still growing (www.CareRails.com) & building addition at the homestead is over budget!
Short Block:
· Ford NOS 427 Side-Oiler - 1968 (only .005 over standard bore)
· 426 ci
· Bore Size: 4.238
· Stroke: 3.781
· Compression ratio is 10.9 : 1
· Forged Steel LeMans Crank (lightened counterweights)
· ARP Main Studs for steel cross-bolted caps
· Custom Forged "Crower" Rods - length 6.488 w/ BB Chevy journals
· Federal Mogul Rod Bearings
· Forged “CP” Pistons custom made to odd bore to save block material (blue prints available -.005 over standard)
· Total Seal Piston Rings
· Comp Cams Solid Roller Cam - proprietary "KCR" cam specs
· Durabond Cam Bearings
· AMP timing set, custom machined for application
· Comp Double Roller Ret. Plate
· Original 427 Steel balancer customized by Mr. Hoyt Grimes
· Melling High Volume "Blue Printed" oil pump w/ ARP shaft
· "Shelby" aluminum water pump
· "Shelby" aluminum front cover (powder coated silver)
· ARP or Total Seal bolts throughout engine
· AVIAD oil pan with windage trey and pick-up
· Modified Oil system (enlarged, de-burred, etc.)
· March Billet pulleys custom fitted with double belts
· McLeod Aluminum flywheel with ARP fasteners
· Carter High Performance Fuel Pump
Heads & Intake
· Edelbrock Perfomer RPM heads - KCR - custom work (flow data available)
· Ford Racing Head Gaskets
· Custom T&D Rocker arm system with head bolt retention method
· Edelbrock 427 Victor Intake port matched to heads (powder coated silver)
· Barry Grant “Mighty Demon” 825 Carburetor customized to engine
· Helling & Stellings Chrome air filter assembly per originals
· “Dove" rear breather plate w/ integral PCV valve from Gessford Machine
· Ford Racing Broze Gear
· Lunati Springs - proprietary specs by KCR (details included to purchaser)
· Tapered chrome molly pushrods
· Improved "Chevy" oiling system for rockers & heads
· "Shelby" late model cast aluminum valve covers with intergral baffles
Ignition:
· MSD Pro Billet distributor with customized advance curves
· MSD 8.5 mm wire set
· High performance Ford alternator (powder coated black)
Item's available to serious parties:
1) Detailed engine build sheet
2) Balancing Certificate
3) Blue printing forms
4) Bob Weight Specifications
5) dyno sheets and head flow data.
This engine has also been hot tanked, square decked, line honed (mains & cam), cylinder's honed with torque plates all with BHJ tooling.
