i used bandb's hand brake set up seems to work.I reversed the suplied cable cut the spring and ground one end to fit in the brake caliper. then cut and driled the mount as in my picture,it seems flimsy untill you bolt threw the fiberglass floor pannel which makes everything more solid. good luck.
the older i get the faster i was.
