Old 05-01-2006, 10:41 PM
phatry5 phatry5 is offline
Cobra Make, Engine: FFR 302 bored 306: 370HP
Send a message via AIM to phatry5
Default 1965 FFR MK2 roadster/cobra for sale
-2003 Factory Five National 3rd place finish in street class (registered in AZ as 1965 Sp Con)
-5.0 EFI Aluminum heads (cnc ported exhaust) approx 370 Horses/ new clutch
- 5 speed pro 5 0 shifter
-Trick Flow TFS-51402001 cam shaft
-Aluminum hyd roller rockers
-Custom intake, 70mm MAF/ 75mm throttle body with EGR spacer
-New high output oil and fuel pumps with 30 pound injectors (car is ready for boost)
-New polished high flow water pump/ new radiator/ system has over flow reservoir to keep coolant in the system
- Motor has braced bottom (girdle)
-MAC headers/ all Chrome exhaust
- Rare Independent rear suspension with Cobra R aluminum center section, almost a 4000 dollar upgrade
- 4 wheel disc brakes
- Tubular front and lower control arms
- Dual chrome roll bars
- All digital gauges/ heater with driver/passenger selector/ wind shield wipers/ horn
- Adjustable driver seat
- Viper alarm
This car drives and handles like a dream. It corners like it is on rails. The car is sunset orange pearl. The car has just over 2000 miles on it, although the odometer says 13,300. When the car went over 1000 miles, all the zeros turned to ones. I will list it at 13,300 miles, but it has less than 2200 actual miles. The only other problem is the water temp gauge will read "hi" after driving it for about 5 minutes. The car does not run hot at all. The stock sender unit is not going far enough down into the water, so it will need to be relocated or a longer sensor will be required. The engine runs immaculately.
The time and effort put into building this car will be evident when you look at it. I am willing to let this car go at [COLOR="Red"]$28,000. This is a steal.I Will consider trade for low milage MB 230 Kompressor.[/color] I am retiring in less than 3 years from the Air Force and about to get married. I love this car, but need the money to go in other directions now. It breaks my heart to sell her, but I know someone is going to be extremely happy with the most impressive FFR I have ever seen. you can contact me at
riffmaster777@aol.com if you have any questions or want more pics.
see link below for pics
http://s26.photobucket.com/albums/c143/riffmast/Cobra/
Hold on tight!!!
