Tranny & rear
I had a C-4 behind my 351W and 3.50:1 rear end gears. To go 60-65 the engine would spin at about 3000RPM. I swapped the C-4 out for an AOD and now to do the same 60-65 the engine only spins at about 2000RPM.
When you do the math, the logic is easy to understand. The C-4 or the C-6 for that matter has a final tranny output ratio of 1:1, meaning that for every rotation of the output shaft the engine has to spin once. With the AOD, the final output shaft speed is .67:1 (overdrive gear), meaning that for every rotation of the output shaft the engine spins 1/3 less than with the C-4 or
C-6. This translates to bringing the RPM's down by a third, 3000RPM's down to 2000RPM's.
With the 3.50:1 rear gears you'll still have the low end punch.
With respect to the TV cable, it is very important to adjust it correctly. If you have too little throttle valve pressure you will fry the tranny. What happens is that the clutch plates try to engage but with insufficient pressure they cannot fully engage so they just spin against each other and wear right down. If you have too much TV pressure the trannny will shift like a kicking mule. In order to correctly set the TV pressure you will need a pressure gauge to corrrectly set the TV pressure at idle. It is best to err on the side of too much pressure and then if it shifts too hard, you can gradually back the adjustment off.
I used a TCI AOD that I got from Summit and the techies at TCI were more than helpful walking me through the TV pressure initial adjustment and setup.
Hope this helps you out.
Tony
