Thread: Thermostat temp
Old 05-02-2006, 11:33 PM
Rick Parker's Avatar
180 degree balanced Thermostat (Robert Shaw) in the cooling currently, strongly considering stepping up to 195 since it really seems to run around 160 degrees on the road. I have the Oil cooler blocked in front but I do not have thermostat on oiling sytem with the cooler. It has a Fluidyne Shelby spec radiator. From what I understand they (Shelby) use the same unit for FIA or 427 models so it seems likely that it could be overcooling with the additional cooling capacity (BTU rejection) (?) I may try restricting the water flow too?
Rick
