I went over yesterday and did a pull. I was puking fluid past a piston in the valve body so overdrive kicked in and spoiled the pull. I was getting 201hp to the wheels and 284pftq at 4805 rpm at that point. Crapola! It didn't do anything nasty to the transmission but I was planning on tweaking a new valve body anyway and rebuilding the aod with aode guts for a wide ratio gearset. Then it will get another pull. For now it isn't a problem since it only happens at wot at 110.
It came to 53.35 but we can cut ten bucks off with a group rate.
60 clicks West of Chu Lai
