Old 05-03-2006, 10:12 PM
Cobra.au's Avatar
Cobra.au Cobra.au is offline
Cobra Make, Engine: Classic Revival, Gen3 ls1, Vortech T-Trim, Motec, tremec M12, wilwood brakes.
It definantly will make life easy using a GMH numbered LS1 I nearly found out the hard way using a new motor with no engine number on it (funny how things appear overnight).
The RTA will imply that a new unstamped engine is not ADR compliant and could evan make you do emission testing or at least tie you up in red tape for a while.
But check with your engineer because I have seen a lot of inconsistantsy in what they think is a problem for rego.
Craig W
