Thanks again. I just ran into another issue with the rear control arms. I bought a set of Energy Suspension poly bushings for the rear, and the uppers fit fine, the lowers are too large. The upper control arms had a Ford PN on them, the lowers do not - the rear-end is an 8.8" I believe out of a late 80's Thunderbird Super Coupe. What control arms did CR supply for this application in 1992? It appears that the metal bushings (inside the rubber) are 3" long, the bushing hole in the control arm are 1.5" diameter, and the control arms themselves are 2.5" wide - meaning .25" of bushing protrudes out of each side.
I already boxed, powder coated and installed the uppers, but I don't want to start welding on the lowers until I am sure I have bushings to fit (the existing ones will probably get trashed from the heat). Do you know what application covers the lower rear control arms?
Tx again,
Cheesy
