Old 05-07-2006, 05:29 AM
392cobra's Avatar
392cobra 392cobra is offline
6th Generation Texan
http://www.drivetrain.com/driveline_angle_problem.html
When the transmission output shaft centerline and axle input shaft centerline are parallel, the u-joint operating angle permissible is length of driveshaft divided by five. Example: A short coupled driveshaft with a 15" length would be limited to 3 degrees maximum operating angle. A 30" shaft would be limited to 6 degrees.
When the transmission output shaft centerline and axle input shaft centerline intersect midway of the driveshaft, the joint angles are equal. However, due to the change to unequal joint angles during up and down axle movement, this is a more undesirable condition than parallel centerlines. In this case, the maximum u-joint operating angle is determined by dividing length of driveshaft by ten. Example: A 15" driveshaft with intersecting angles would have a 1.5 degree permissible operating angle.
