Thanks for the posts everyone.
I got 2 major things I needed.
Sleep
Angle finder"the real one"
So here I am. My last and final plan is to degree these 2 as close to 0 as possible .
What I understand is. zero would be a direct line from pinion to output.
Leaving more than enough - and + u joint travel.
But If need be 5 degrees is the maximum offset I should shoot for.
Anything more than this will give too much + travel to the pinion/driveshaft and throw the u joint/driveline out of its balance??
Now what IM understanding is.....your saying left to right angle could be offset?
Im supposing since there is no left to right travel.
Like there is suspension travel up/down,I wont have to worry about that + and - movement?
I hope this comes together,im not in the mood to use adjustable control arms or shim up ANYTHING IN THE REAR.
