Fred Thanks again,
I got it now.
Just for giggles,I went and grabbed a crazy engineering lensatic degree compass,it registers just as good as the protracter suprisingly..Its the only thing i can find to measure left/right angle so this way ill be sure my output shaft is straight.Thus my modified x member will be correct.
I know it "should be" in relation to the old x member slots,but IM done playing games.
Fred,the last thing I need to triple check is"I need to do this all while the suspension is compressed right?
What about the front suspension?
I ask this because,I use a frame lift.I put a spin jack under the rear and a brace"another spin jack" in the front so it wont tip over/off forward.
SO I only would be getting the rear to compress.
Do you think this is ok?
I dont have access to a drive on lift and the liftarms wont reach the suspension to lift it that way.
I really appreciate the posts
Thanks
Dan
