Did you flush the fluid yet? Your fluid is likely getting hot from the exhaust and is probably old, contains water and is boiling. That prevents the slave cylinder from releasing the clutch all the way and you car wont go into gear. You need the be able to do, or have done locally, maintanance as basic as bleed a clutch if you want to own a Cobra, there will be other little things like this down the road. Try asking a local auto parts store if they know anyone.
