(SBF) small block ford. With a small block you can get to it from the top...with a big block you wouldn't be able to get to the slave from the top. You'll see as time goes on that the big block guys like to make fun of us small block guys.
Have someone sit in the drivers seat push the clutch to the floor and hold it there, you turn the bleed screw letting the air and fluid out, tighten the screw back up, they release the clutch and start the process over again until it seems all the air is out. Refill your resevoir and your done. Make sure you don't totally deplete your resevoir and suck air into the system.
trig
