Old 05-15-2006, 02:07 PM
lnfletcher's Avatar
lnfletcher lnfletcher is offline
Cobra Make, Engine: B&B 427 Stroked Windsor TKO 600 w/3.50 posi 9"
Mine was like that when I received it. It can get in a bind if the shipper set it on end. I put a rag around the input shaft and worked it back and forth with my hand and then some channel lock pliers (being careful not to mar the splines) and it finally broke loose when working it with my hand. I had put in a call to the seller of my transmission and had it freed up before they called back.
