I just took my SPF home this weekend!!! I'm very pleased with the car, I wanted to go for an all about business look in the engine compartment, IDA's, aluminum block and AFR heads. Eric at Performance Engineering In Ross OH fabricated a high volume
oil cooler set up for the 427 stroker. It has a reusable/cleanable
oil filter and a very clean install. It really looks very much like the SPF unit only with slightly larger SS
oil lines. I've been told that the SPF unit is not eficient enough for track driving and many engine builders will not stand by their engine if that cooler is hooked up. Eric wil warrantee his engines with the high volume oil cooler, and best of all its functional. No poser non functioning parts on a Cobra!!
