I got mine from Summit. It is an aluminum cylinder with mounting ears and works very well.
I drilled and tapped the right shock tower ( if you want to call it that ) and put braces between the tank and the tower. It sits right in front of the Alternator, so, it may not work for your setup if you are running a shroud.
I put a purge hose from the neck to the tank and let the overflow run out the bottom of the car, if it ever does.
What ever one you end up with, get one that is of good quality and will mount well int he engine compartment. You do not want one that will come loose.
Just my $0.02
