Old 05-18-2006, 08:40 PM
jarendall jarendall is offline
Cobra Make, Engine: StreetBeast 66 replica 302 350HP
you do have a wiring problem, if properly grounded, the front and rear lights should not cross feed, you are cross feeding through your bulb elements, make sure all bulb housings have a ground wire connected to them, if this is not the problem, then the turn signal wiring is shorted some where, or not properly routed, check your wiring diagram for the turn signals
PapaJohn
