Old 05-21-2006, 01:55 PM
Jim Vander Wal Jim Vander Wal is offline
Cobra Make, Engine: FFR Challenge Car, RDI aluminum 427w
I'm running AN-12 lines for all connections, the Canton cannister oil flter and thermostat and Rob Frink's remote oil adapter. Seems to be working well with oil pressure at 50-55# during normal operation. Hasn't been warm enough for the t-stat to kick in and send oil to the cooler. The Canton t-stat seems to pass oil very well. This is much better unit than most of the other t-stats that I evlaluated and read about.
The cooler is an Earl's piece of the same size as the stock SPF unit but with AN-12 fittings.
I had all of these pieces and an Accusump before Rob's filter / cooler switch was available or I would have gone with Rob's setup.
I can only second the great reviews of Rob's work. Great machining, clean simple design.
Running on the track and ambient temps of about 80f you will need the cooler. With the cooler in place I run up to 120c; I wouldn't chance track time w/o the cooler.
Jim SPF 1855
