Bob,
After installing the new Trigos, it appears that the rear of the car needs to come down 1.00", however I am not certain what shim thickness would be required for that reduction in height. Any suggestions that you might have would be much appreciated. I will call this week to provide my billing info.
Also, thank you for your help with the tach issue last week. No MSD adapter was required - I had a fuse that did not look bad, but was. The original tach now works fine straight from the MSD 6AL box.
Thank Again!
