Old 05-29-2006, 07:57 AM
You want a cam that will make max power with a 112 center line. You know that the carbs are out of air around 62-6400 rpm. motor is way to big for them. A dual pattern will work GREAT with them. Get some one to run some dyno sims on the motor with a couple of different cams. I have talked to 2 of the best that run webers. You power range should be between 2400 and 5800 rpm. You can run a bigger cam than what they may call for. The Webers take out some of the overlap and lift. If setup right you will get 20-40 hp more in the mid range and 18-35 ft of tork than any carb. If you want to talk call me at 732-254-3536 in the evening and I should be home. Rick l
