  #34 (permalink)
Old 05-30-2006, 03:54 PM
HSSS427's Avatar
HSSS427 HSSS427 is offline
Cobra Make, Engine: ERA #414 427 s/o w. Shelby Aluminum heads, Edelbrock Performer RPM Intake, Mighty Demon 750, Tremec TKO 600
Default Time to put it back together
OK,
The heads and intake are off
The oil pan is off - letting the sludge drain out and will wipe it down
Wiped down the lifter valley to get the sludge out
What do I need to think about for re-assembly?
- Do I need to worry about getting every drop of water out of the block? If so, how do I?
- Anyone have the torque specs for the following handy:
- Shelby aluminum heads
- Aluminum intake
- Aviad Oil pan
- Looking for a set of Fel-Pro gaskets - where should I use Permatex instead, where shoud I use no Permatex, and where should I use both?
- I notice that my engine doesn't have a tray over the lifter valley as shown in several books - do I need this?
- Go the following start up tips in mind:
1. Prime the oil pump and system - leave the valve cover off so you can see the oil coming in
2. Get the initial timing as close as possible before starting and adjust as quickly as possible - forgot to mark the distributor before removing it so will have to eye ball it using the timing marks and distributor rotor location
3. prime the carb so I don't wear out the starter, and engine, waiting on the bowls to fill (mechanical pump on mine)
4. Oh yeah, MAKE SURE THE BLOCK IS FILLED WITH COOLANT!!!
