Old 06-02-2006, 04:39 PM
HSSS427's Avatar
HSSS427 HSSS427 is offline
Cobra Make, Engine: ERA #414 427 s/o w. Shelby Aluminum heads, Edelbrock Performer RPM Intake, Mighty Demon 750, Tremec TKO 600
Default Repairing a leaky surge tank
It appears the joint connecting the pipe on the bottom of my surge tank is leaking. Is this just a simple job of running solder over the joint to seal it up, or is it more complex due to the pressure involved? It's not a very big leak, but it does dribble out through what appears to be a pin hole in the joint weld. I believe the tank is made of brass and is painted black. I've stripped away the black paint around the joint. Appreciate any advice and tips!
Thanks!
Scott
