Old 06-04-2006, 11:10 AM
Power Surge's Avatar
Power Surge Power Surge is offline
Originally Posted by strictlypersonl
If your front pin-drives use adapters on a standard bolt-on hub, the the caps are not needed. The ERA 6-pin system's one-piece hubs need them. I haven't seen a rear design that needed 'em.
I think what he means Brent, is if you are running a real 6 pin setup (like CSXs, KMPs, ERAs 6 pin, etc), then you need them. If you are using the Trigo 5 lug adpaters, then you don't. For your KMP, you need them on the front, but not the rear (just like original cars).
Sal Mennella
