Thread: oil coolers
Old 06-06-2006, 12:15 PM
*13*'s Avatar
*13* *13* is offline
If you have the set up supplied by B&B & they suggest it will work then check all obvious things before you give them a call for experienced advise. Timing, Thermostat rating, carb jetting, correct rotation water pump & volume, good coolant flow & so on...
ERA FIA 2088
