Old 06-08-2006, 07:00 AM
stephen low's Avatar
stephen low stephen low is offline
Default Engine fuel usage specs
Does anyone have data or know where to point me to get an idea of the fuel demand of the engine I am using. I ask as I am trying to source an in-tank pump option for my G-Force over the external 2 pump and pot option.
Am using a 5L 220kW Windsor from an AU2.
Biggest difficulty is trying to find a standard commercial pump/sender/swirl pot that will fit the 200mm tank depth of the G-Force tank. Think I am close with an XE-XE pump unit at 210mm depth but believe I will need to upsize the pump if not from a V8 model.
Can anyone help?
slowy
